ID Tool 3
dennisp
I purchased Plant Art for Landmark. I imported them into the Resource palette. After selecting them into my design I chose Create Symbol, named it, and placed it into Plant Catalog. The file has been saved. Then I selected the Place Plant Tool, my symbol is in the Plant Catalog, I choose the symbol and now I am in the 'Set Default Plant Tool Options. When I hit edit a totally different symbol appears in the 'Edit Plant Catalog' screen, the original plant is not available. How do I get the original symbol into the Plant Catalog?
More info: I've imported symbols that I created in other programs, and purchased through VectorDepot. I can attach a Plant Record and the ID Tool will label them (although I cannot edit the label?). Although I can place them in the Plant Cat., and I can select them graphically when using the Place Plant Tool, I cannot edit them further.
IF I place them in the 2D syms folder and go to AEC - EDIT PLANT CAT I can select the symbol in the 2D Syms folder, define it, find the symbol location again(symbol is not showing in box). When I select the Place Plant Tool now the symbol I just edited is still selected and places in the design. Now I choose Show or Hide Tags from the View menu and my symbol has a Tag. Success! I think. If this works I'm on my way. Thanks for your help.
