Setting Viewport Class Overrides
Sam Jones
Is it possible to set the visibility of a class in a viewport with vector script.  I would want to create a class override and set the visibility of the class to either visible or not visible.  It seems possible to set all sorts of class attributes but not visibility.
Also, is is possible to set the viewports "Adjust flipped text" setting?
Hoping this is possible, and I am maintaining my inability to search the function reference with any skill.
You should be able to set the "Adjust Flipped Text" setting using SetObjectVariableBoolean(viewportHandle,1029,TRUE/FALSE).
No worries about the function reference, it's a tricky thing to navigate.  There's so many things you can do using object variables, but it involves poring through the appendices.  I've gotten pretty good at using Ctrl+F to find what I'm looking for.
