This is probably one of those "Duh" questions so please forgive:
Basically, when rotating a model view using CTL + mouse scroller button one can set the rotation point where wanted. But move the view where that point is not within the display window and the next attempt to rotate finds the point relocated elsewhere.
It will stay put when obscured by other objects in the model but moves when the view has moved it off the display window. Then it can go anywhere.
Is there a setting that causes this rotation point to move only when moving it by using the CTL + mouse button or similar?
