Bruce Kieffer Posted January 11, 2021 Share Posted January 11, 2021 I've filleted these corners. How do I modify the size of the radius corners after the fact? Quote Link to comment
Pat Stanford Posted January 11, 2021 Share Posted January 11, 2021 In VW2021 you can enter the history and edit the fillets. In VW2020, you have to Ungroup to undo the fillets and then redo them. Quote Link to comment
Bruce Kieffer Posted January 11, 2021 Author Share Posted January 11, 2021 (edited) Can't get to history mode on these rectangles. Only edit mode. I recall double clicking them use to go to history mode, but not now. These are 2D shapes. Edited January 11, 2021 by Bruce Kieffer Quote Link to comment
grant_PD Posted January 11, 2021 Share Posted January 11, 2021 You can't edit the 2d like you can on a 3d shape like that. But you could use the rounded rectangle tool and achieve what you want. Rounded rectangles would allow you to change the fillet. 1 Quote Link to comment
Bruce Kieffer Posted January 11, 2021 Author Share Posted January 11, 2021 2 minutes ago, grant_PD said: You can't edit the 2d like you can on a 3d shape like that. But you could use the rounded rectangle tool and achieve what you want. Rounded rectangles would allow you to change the fillet. Good solution. Thanks Quote Link to comment
Bruce Kieffer Posted January 11, 2021 Author Share Posted January 11, 2021 (edited) For 2D shapes like this that can't be created without the fillet tool rather than the rounded rectangle tool, it's better to extrude them with square corners then use the 3D fillet edge tool to "cut" round overs, at least then you can use history mode to explore the look of different rad. round overs. Edited January 11, 2021 by Bruce Kieffer Quote Link to comment
Bruce Kieffer Posted January 11, 2021 Author Share Posted January 11, 2021 Honestly, history mode should be available for every add or subtract operation. 1 Quote Link to comment
