Gabriel Chan Posted January 9, 2021 Share Posted January 9, 2021 Looking at the screenshots attached, we see that the data in the OIP does not make sense: DMX Address: 27.40kg I have already replaced the fixtures with lighting symbols from the 2020 library. The 2 screenshots are both of MAC TW1. One from the old file and 1 from the new library. Is there any quick solution to resolve this, or am I looking at manually replacing 200 over fixtures? Gabriel Quote Link to comment
Vectorworks, Inc Employee klinzey Posted January 11, 2021 Vectorworks, Inc Employee Share Posted January 11, 2021 If you have customized the OIP in Spotlight Preferences try reverting the the default set and see if that solves the issue. If you continue to have the issue please submit a bug report with the Vectorworks 2017 file so that we can investigate the problem. https://www.vectorworks.net/support/bugsubmit Quote Link to comment
Gabriel Chan Posted January 11, 2021 Author Share Posted January 11, 2021 Hi Klinzey, I found a work around to it by just copying everything and pasting it onto a new file. The OIP fields then lined up. I checked my OIP Spotlight Preferences and indeed there were some customisations, probably over the course of 10 years of use. Before setting it to default, I wanted to keep whatever might have been customised so I saved a custom settings for lighting device parameter, and upon saving it the OIP fields lined up. I suspect somewhere along the lines these settings might not have refreshed when importing an older file, so all is good now, although this would definitely not be very intuitive to the average user. If there is any SP update for 2020 remaining perhaps this bug should be squashed. Great to know a solution for it though! Thanks! Gabriel Quote Link to comment
