Joliphant Posted June 26, 2001 Share Posted June 26, 2001 How do I get the degree symbol when typing bearings in degress, minutes, seconds? Quote Link to comment
CipesDesign Posted June 26, 2001 Share Posted June 26, 2001 On a Mac, with most fonts, degrees (?) is SHIFT-OPTION-8. Some fonts are different. Check with your font maker... Quote Link to comment
Joliphant Posted June 27, 2001 Author Share Posted June 27, 2001 quote: Originally posted by CipesDesign: On a Mac, with most fonts, degrees (?) is SHIFT-OPTION-8. Some fonts are different. Check with your font maker... Thank you for the response. However, I use a pc. I will check with the font to see if I can figure it out. Thanks. Quote Link to comment
Guest Posted June 27, 2001 Share Posted June 27, 2001 quote: Originally posted by Joliphant: How do I get the degree symbol when typing bearings in degress, minutes, seconds? It's probably easier to use 'd', 'm', 's'. If you type '24d15m39s', VectorWorks will know what you mean. Quote Link to comment
Joliphant Posted June 28, 2001 Author Share Posted June 28, 2001 Caleb: Thank you. Quote Link to comment
Joliphant Posted June 28, 2001 Author Share Posted June 28, 2001 Thank you very much, Caleb! quote: Originally posted by Caleb Strockbine: It's probably easier to use 'd', 'm', 's'. If you type '24d15m39s', VectorWorks will know what you mean. Quote Link to comment
