LeeElston 8 Posted January 7 I have 2 window objects above each other in the same wall, one a normal window, the other a louvre at high level in a gable wall. I have put the louvre in a seperate class which I have turned off, but the opening is still being shown in the plan view. whilst the opening of the lower window is not cut into the wall... I attach screenshots showing issue. Sketch 1, shows both classes turned on, sketch 2 is with the HL louvre turned off. Any tips appreciated.. Quote Share this post Link to post
Matt Panzer 876 Posted January 7 Try selecting the louver window object and select the Clerestory option in the 3D Visualization pane. That will have it show as dashed above without breaking the wall in Top/Plan view. Alternately, you can simply select "No Break" in the Break popup in the Object Info palette: Either way, you can still use classes to turn the visibility of the window off as before.. 2 Quote Share this post Link to post
LeeElston 8 Posted January 7 Many thanks... easy when you know how!! Quote Share this post Link to post
