Connecting lights on sloped truss
Good morning. I would like to ask if this procedure is correct: I want to connect some lights to a sloped truss. In top / plan view they seems connected correctly, but in 3d it is not verified. Does this mean that you have to redo the connections twice? If you redistribute the lights from top view the connections are not easily controllable.
How should you proceed correctly? Thanks
  • 4 weeks later...
Hi Pier, No you can attach lights to pre-existing raked trusses, in a 3d view you can snap a light to a raked truss. However I find it much easier to create these exactly how I used to in real life in my previous career. Then once assembled, flown and rotated into position.
