bclydeb Posted June 20, 2001 Share Posted June 20, 2001 I have to use a HP 450C plotter to plot VWA files. If I am using VWA9 with a file developed from scratch -the machine seems to plot fine. However - legacy files, those which I have passed through MiniCAD (v1.9x!) through succeeding iterations until VW8.x - plotted fine as long as it was a 8.x file. We're talking Windows 98 here folks. Now, I have converted the file one more time into VWA 9 and it no longer plots! The results are that it appears to plot only one layer. the layer plotted is not the top, nor the bottom nor the active layer. Each different file plotted has a different layer plotted. All other layers do not exist. Checking other sources and HP troubleshooting suggests using an HP750C or C-plus driver since adding the C-kit to the 450 plotter to make it a 450C effectively changes it to a 750C type plotter. Again no go. either get a single layer only or - when using HP's prefview selection, SOLID BLACK! Any solutions, besides pop the big bucks for a new plotter or have to spend the big bucks on remote plotting services and overnight delivery? I am a small office and affording other options is not an option. Quote Link to comment
Rob Glisson Posted June 20, 2001 Share Posted June 20, 2001 Hang in there, the upgrade should be out very soon! We use the same plotter, use Macs (always a good idea!) and have exact same problem. We save to 8.5.2 and plot from there, seems to work fine. We are actually using 852 until upgrade comes out, everything working fine. Good Luck. Quote Link to comment
Speedy Gonzales Posted June 21, 2001 Share Posted June 21, 2001 I have had similar problems. The simple solution until the fix is out is to continue working in version 8.x.x (8.5.2 Mac). If you like VWA 9, then START your new projects in it, and all will be fine. A major problem is in their translator. Quote Link to comment
