Preview button ti update a PIO...
I've got an event-enabled linear PIO that raise a custom dialog with a double click on it. It works fine swapping values between custom dialog and info object palette. I've implemented dialog handle procedure with item 1 (OK Button), item 2 (CancelButton). Now I would like to add item 12605 (preview button) which would operate as the Ok button (updating PIO ), but without exit from dialog. It doesn't work at all because seems that  you must exit from the dialog event loop to obtain PIO updating.
Thanks in advance for any suggestion.
Edited by alberto72
I tried to implement your advice but it was unsuccessful. It seems that only some instructions are executed during the dialogue loop such as:AlrtDialog(), CreateText()+ReDrawAll(). Here is my Dialog_Handler function which I'm working at.....
def Dialog_Handler(item, data):
        (ok, objectName, objectHand, recordHand, wallHand) = GetCustomObjectInfo()
        def update_and_execute():#===== this subroutine is intended to be used with item==1 and item ==12605
            # ========retrieving values======
            esito,inter.c1 = GetEditReal(dialogID,12,3)
            esito,inter.c2 = GetEditReal(dialogID,14,3)
            (outSelectedIndex, outSelectedChoiceText) =GetSelectedChoiceInfo(dialogID, 16, 0)
            inter.d = outSelectedChoiceText
            # ========= updating object info palette===
            SetRField(objectHand, GetName(recordHand), 'ci',str(inter.c1/10) )
            SetRField(objectHand, GetName(recordHand), 'cf',str(inter.c2/10))
            SetRField(objectHand, GetName(recordHand), 'diam', inter.d)
            ResetObject(objectHand)
        if item == 12255:# SetupDialogC -> My Custom Window Init
            AddChoice(dialogID, 16, '8', 0)
            AddChoice(dialogID, 16, '10', 1)
            AddChoice(dialogID, 16, '12', 2)
            if v3 =="8":
                choice = 0
            elif v3 =="10":
                choice = 1
            elif v3 =="12":
                choice = 2
            SelectChoice(dialogID, 16, choice, False)#=====update pulldown menu -> OK!
        elif item == 2:#=====Cancel button pressed -> OK!
            pass
        elif item ==1: #====  OK button pressed -> OK!
        elif item == 12605 :# ======Preview button pressed ->
            AlrtDialog(('item= '+ str(item) + '   data= '+ str(data)))#===== THIS WORKS
            update_and_execute()#=====THIS DOESN'T REGENERATE PIO AS item==1 DOES !
            ResetObject(objectHand)#=====THIS DOESN'T WORK TOO !
            CreateText(str(item))#==== THIS WORKS WITH ReDrawAll() !
            ReDrawAll()
