EvelyneB 5 Posted January 4 Hello, I'm having trouble with a few display issues in my hidden line elevations. These seem to only show up in hidden line render mode, not in OpenGL (I've attached a PDF of both to illustrate the issues). Issue #1 : The surface hatch of the siding is missing on part of the elevation (PDF attached). The wall itself is continuous, but the texture is getting interrupted for some reason (shown in pink in attached PDF) Issue #2: window IDs - the window ID text is missing from the East and some South windows. The ID hexagon is there, but the text is missing (shown in green in attached PDF). I checked and the ID text class is turned on. The second window ID issue is that some window IDs from the opposite side of the building "ghosts" through the building (shown in cyan in attached PDF). Any idea what might be causing these issues in hidden line render mode? Thanks! Elevation window ID issue_OpenGL.pdf Elevation window ID issue.pdf Quote Share this post Link to post
EvelyneB 5 Posted January 18 No responses yet... Could someone please help me out here? I have the same issue in multiple files, and I'm stumped as to why it is occurring. I just installed the latest service pack, but the problem persists (VWX 2021 SP 2.1) Any help would be much appreciated! Thanks. Quote Share this post Link to post
Wes Gardner 334 Posted January 21 @EvelyneB, can you post the file? Wes Quote Share this post Link to post
EvelyneB 5 Posted February 16 Hi @Wes Gardner, Here is the file. The sheet layer with the elevations where this glitch occurs is on screen when you open the file. Thanks for your help! 210208_J&E_glitch.vwx Quote Share this post Link to post
Wes Gardner 334 Posted February 16 @EvelyneB, I passed your file on to Tech Support....they should have an answer for you. Wes 2 Quote Share this post Link to post
michaelk 540 Posted February 16 @EvelyneB Not sure why but the hidden line hatch works in an elevation (front, back, left, right) view. Not sure why it fails in a section view. But if you try that viewport as a back view rather than a section it works. You might also want to check "Use World Z for Origin" in the render tabs for the walls to make sure the texture bridges the first and second floors. 1 Quote Share this post Link to post
Rob Nykolaishen 2 Posted March 4 @EvelyneB I apologize for missing this, I have sent you a DM and will be in touch through email. Rob Quote Share this post Link to post
niagara designer 8 Posted April 14 Are there any solutions to this that have been shared? I have a similar problem - one wall type shows the surface hatch in hidden line elevation VP - other different walls do not. settings seem to be the same for the various walls -ie in OIP - render by component. wall components seem to have same types of settings appropriate to their surface/material... display surface hatch on in background settings. classes are on....what to try next? thanks Quote Share this post Link to post
Boh 507 Posted April 14 @niagara designer can you post the file and some screenshots showing where the problem is? @EvelyneB Can you reveal how you resolved your issue? I also recently noticed some issues with window ID not displaying correctly in Elevations created from section viewports. The problem went away when I used a standard viewports in Front, Back, Left and Right views. Quote Share this post Link to post
EvelyneB 5 Posted April 15 To fix the window IDs, I check the box for "Display 2D fills" in the viewport's OIP. Unfortunately I haven't found a solution to fix the triangulated interruptions in the textures. A Vectorworks employee contacted me and this seems to be a glitch. The workaround is to draw in the missing patches in annotation with a polyline with a hatch fill and carefully align it to the rest of the wall's texture. Needless to say, it's a huge pain and does not update automatically if anything changes in the model, but it's all I've found for now. Quote Share this post Link to post
Boh 507 Posted April 15 (edited) Thanks, I hadn't noticed the "Display 2d Fills" check box. I had a play with your file and found that if you delete the wall bottom peaks it seems to resolve the issue: Edit: I see though you want a bottom offset. So instead of using a bottom offset, with the wall selected, use the reshape tool to drag the bottom of the all down. This gives the same look but no "bottom offset". Alternatively something else that might work is use another wall style that has the btm offset as part of the actual style. This way might be better as just the cladding can have the bottom offset rather than the whole wall. Edited April 15 by Boh 2 Quote Share this post Link to post
EvelyneB 5 Posted April 15 Thanks, @Boh! That's very helpful. Puzzling that this is the solution, but helpful all the same😉 1 Quote Share this post Link to post
niagara designer 8 Posted April 15 thanks everyone - I found the problem with the hidden line surface hatch not showing . feel like a dummy - I had to edit the actual wall styles in the RM - the siding components had a default setting for the class material of steel for some reason... I was sure I had checked that, but...guess not. thanks again 1 Quote Share this post Link to post
