Vectorworks, Inc Employee Stephan Moenninghoff Posted February 25, 2021 Vectorworks, Inc Employee Share Posted February 25, 2021 (edited) 21 hours ago, Daisy Y said: @Stephan Moenninghoff I want to use a leg on my cabinets that isn't in the standard library of parts that came with the software. How do I go about adding this? The leg is a Hafele part that comes as a foot shaft and foot plug top. Links to the parts here: https://www.hafele.ie/en/product/plinth-foot-top-section-m10-screw-through-mounting/000000fb0003ab5f00020023/ https://www.hafele.ie/en/product/foot-and-shaft-section-for-adjustable-plinth-feet-plastic/63796331/?MasterSKU=0000001c0001b63f00020023 Will I need to model something up myself to represent these and then add that as a part in my part library? Or is there a place to download this product and upload it into my library? Hi Daisy, it's easily possible with interiorcad's built-in "Edit / Adapt Fitting Libraries" command. Go to interiorcad and then Fittings: From the next dialog, you choose feet and mounting plates (and, if required, accessories and / or glides). When you choose each command for the first time, interiorcad will create a new document with a sample fitting. When you save it, it will be placed in your user folder ( /Users/<your user name>/Library/Application Support/Vectorworks/2021/Libraries/Defaults/Custom Part/Leg Feet/Leg Feet - Custom.vwx) or, if you're on Windows in C:\Users\<your user name>\AppData\Roaming\Nemetschek\Vectorworks\2021\Libraries\Defaults\Custom Part\Leg Feet\Leg Feet - Custom.vwx (or Leg Mounting Plates). Edit the sample fitting geometry and replace the sample geometry with your own geometry. Add drillings if required. make sure you don't ungroup anything. Work inside the groups because there are Vectorworks Record Formats attached to the enclosing groups. If you do it like that you'll be fine. If it does not work, which is to be expected, because it never works the first time around, 😁 , upload what you tried here (the documents from your user folder) and I will have a look. Edited February 25, 2021 by Stephan Moenninghoff Quote Link to comment
Daisy Y Posted March 1, 2021 Share Posted March 1, 2021 @Stephan Moenninghoff Thank you for the previous reply! I'm having another issue, I'm saving symbols within symbols (ie. the symbol of a drawer type within the symbol of a full cabinet) and when I close my program and reopen the file it has converted the symbols (drawers) within the main symbol (cabinet) into a group and so lost its symbol nature and ability to edit symbol capabilities. I'm also getting this error message when opening the file, " Some object connections are broken in the current document" , asking me to repair items. I'm not sure why this message is appearing or if it's anything to do with my symbol-within-symbol issue. Quote Link to comment
Vectorworks, Inc Employee Stephan Moenninghoff Posted March 1, 2021 Vectorworks, Inc Employee Share Posted March 1, 2021 10 minutes ago, Daisy Y said: @Stephan Moenninghoff Thank you for the previous reply! I'm having another issue, I'm saving symbols within symbols (ie. the symbol of a drawer type within the symbol of a full cabinet) and when I close my program and reopen the file it has converted the symbols (drawers) within the main symbol (cabinet) into a group and so lost its symbol nature and ability to edit symbol capabilities. I'm also getting this error message when opening the file, " Some object connections are broken in the current document" , asking me to repair items. I'm not sure why this message is appearing or if it's anything to do with my symbol-within-symbol issue. That's interesting. I don't think converting drawers into symbols is a good idea, they need to live inside the main symbol as groups/plugin objects. You can attach the file here if you like and I will have someone take a look. Quote Link to comment
Daisy Y Posted March 1, 2021 Share Posted March 1, 2021 Oh they weren't interiorcad drawers they're custom drawers I have just made from Custom Parts and shapes as I only wanted certain parts to export in the NC export as we will be cutting certain parts on the saw for our dovetail joined drawers and others were employing Hafele TandemBox drawer sides and so we only needed a base and back panel. I've attached the file. In it you'll see a collection of cabinets, I was working in the 'Shark 1200 3 drawer' and the 'Shark 1200 2 drawer' when I mainly noticed the problem but I think it happens to all of the symbols. Cabinet 3D Library.vwx Quote Link to comment
Daisy Y Posted March 1, 2021 Share Posted March 1, 2021 1 hour ago, Stephan Moenninghoff said: That's interesting. I don't think converting drawers into symbols is a good idea, they need to live inside the main symbol as groups/plugin objects. You can attach the file here if you like and I will have someone take a look. Oh they weren't interiorcad drawers they're custom drawers I have just made from Custom Parts and shapes as I only wanted certain parts to export in the NC export as we will be cutting certain parts on the saw for our dovetail joined drawers and others were employing Hafele TandemBox drawer sides and so we only needed a base and back panel. I've attached the file. In it you'll see a collection of cabinets, I was working in the 'Shark 1200 3 drawer' and the 'Shark 1200 2 drawer' when I mainly noticed the problem but I think it happens to all of the symbols. Cabinet 3D Library.vwx56.38 MB · 0 downloads Cabinet 3D Library.vwx Quote Link to comment
Daisy Y Posted March 1, 2021 Share Posted March 1, 2021 Is there a way of creating new frame styles for the fronts of cabinet doors? At the moment I am using a standard door and then drawing a custom part 6mm plant on but it isn't parametric so I have to redraw the frame for each different size cabinet? I've attached one example of the style of frame I am wanting to apply to the front of my cabinets. The divisions of the small horizontals would change with taller units to divide equally along the door height. Also is there a way around the fact you can't seem to edit a door of a cabinet without deleting the shelves/division first to edit the door and then re-adding the division back in? Quote Link to comment
Nicolas Goutte Posted March 1, 2021 Share Posted March 1, 2021 (edited) 16 minutes ago, Daisy Y said: Is there a way of creating new frame styles for the fronts of cabinet doors? At the moment I am using a standard door and then drawing a custom part 6mm plant on but it isn't parametric so I have to redraw the frame for each different size cabinet? I've attached one example of the style of frame I am wanting to apply to the front of my cabinets. The divisions of the small horizontals would change with taller units to divide equally along the door height. In short: make a cabinet door and then in the dialog change the door from "Plain" to "Frame". (That is new of interiorcad 2021.) Quote Also is there a way around the fact you can't seem to edit a door of a cabinet without deleting the shelves/division first to edit the door and then re-adding the division back in? Again, here too, in short: in the dialog, tab "Division", select one box, then click the symbol with the arrow for expanding the selection, until you have the right selection for the door you want to change. Check the documentation at: https://conf.extragroup.de/display/IM/Division+Tab if you need more information to were that symbol for expanding the selection is. Edited March 1, 2021 by Nicolas Goutte Quote Link to comment
Daisy Y Posted March 1, 2021 Share Posted March 1, 2021 36 minutes ago, Nicolas Goutte said: In short: make a cabinet door and then in the dialog change the door from "Plain" to "Frame". (That is new of interiorcad 2021.) Again, here too, in short: in the dialog, tab "Division", select one box, then click the symbol with the arrow for expanding the selection, until you have the right selection for the door you want to change. Thanks Nicolas! The first point helps a little, it lets me edit the frame that goes round the outside but it doesn't allow me to create a detail style of door I can apply to different units (ie, with mini sub rails that divide up the door creating a sort of grid look over the door). Perhaps this isn't a possible feature available yet? Point 2 - you are a lifesaver this is amazing thank you! Quote Link to comment
Vectorworks, Inc Employee Stephan Moenninghoff Posted March 1, 2021 Vectorworks, Inc Employee Share Posted March 1, 2021 @Daisy Y I have just finished a 11-part tutorial to get you up to speed with exactly how these things are done. It will soon appear on a screen near you. Stay tuned until mid-March for more news on this. Quote Link to comment
Vectorworks, Inc Employee Stephan Moenninghoff Posted March 1, 2021 Vectorworks, Inc Employee Share Posted March 1, 2021 2 hours ago, Daisy Y said: Thanks Nicolas! The first point helps a little, it lets me edit the frame that goes round the outside but it doesn't allow me to create a detail style of door I can apply to different units (ie, with mini sub rails that divide up the door creating a sort of grid look over the door). Perhaps this isn't a possible feature available yet? Can you show us what you have in mind? Maybe we can integrate it or maybe you can already do it. Quote Link to comment
Vectorworks, Inc Employee Stephan Moenninghoff Posted March 1, 2021 Vectorworks, Inc Employee Share Posted March 1, 2021 4 hours ago, Daisy Y said: Cabinet 3D Library.vwx 56.38 MB · 1 download This works for me. Did you have "Convert to Group" checked on creation by any chance? Quote Link to comment
Tobias Döngi Posted March 2, 2021 Share Posted March 2, 2021 21 hours ago, Nicolas Goutte said: Quote Also is there a way around the fact you can't seem to edit a door of a cabinet without deleting the shelves/division first to edit the door and then re-adding the division back in? Again, here too, in short: in the dialog, tab "Division", select one box, then click the symbol with the arrow for expanding the selection, until you have the right selection for the door you want to change. You can do this even faster by holding the alt key down while clicking the desired box. 2 Quote Link to comment
eddc Posted June 1, 2021 Share Posted June 1, 2021 Hello How can I install the english version of Vectorworks Interiorcad for student? Quote Link to comment
Vectorworks, Inc Employee Stephan Moenninghoff Posted June 2, 2021 Vectorworks, Inc Employee Share Posted June 2, 2021 16 hours ago, eddc said: Hello How can I install the english version of Vectorworks Interiorcad for student? Go here: https://en.extragroup.de Then, download educational version. 1 Quote Link to comment
eddc Posted June 2, 2021 Share Posted June 2, 2021 Thank you! Sr. Stephan Moenninghoff Quote Link to comment
Popular Post Habitat43 Posted July 9, 2021 Popular Post Share Posted July 9, 2021 Hello community, it's been a while since I post anything here. Wanted to share one of my latest projects using InteriorCAD cabinets. The rendering is done with Vray. Thanks! 7 1 Quote Link to comment
Vectorworks, Inc Employee Stephan Moenninghoff Posted July 9, 2021 Vectorworks, Inc Employee Share Posted July 9, 2021 12 hours ago, Habitat43 said: Wanted to share one of my latest projects using InteriorCAD cabinets Thanks for sharing. Nice project! Quote Link to comment
E|FA Posted May 27, 2023 Share Posted May 27, 2023 On 1/10/2021 at 9:25 PM, Stephan Moenninghoff said: Textures and materials are one entity in interiorcad. Each material has a texture and a thickness assigned to it as well as a 'material type' I'm testing the demo version of XS, and trying to get my head around InteriorCad "materials". Are they related in any way to VW "Materials" resources? Is there a way to coordinate them in terms of reporting, graphics, etc? Quote Link to comment
Tom W. Posted May 31, 2023 Share Posted May 31, 2023 On 2/25/2021 at 8:15 AM, Stephan Moenninghoff said: Hi Daisy, it's easily possible with interiorcad's built-in "Edit / Adapt Fitting Libraries" command. Go to interiorcad and then Fittings: From the next dialog, you choose feet and mounting plates (and, if required, accessories and / or glides). When you choose each command for the first time, interiorcad will create a new document with a sample fitting. When you save it, it will be placed in your user folder ( /Users/<your user name>/Library/Application Support/Vectorworks/2021/Libraries/Defaults/Custom Part/Leg Feet/Leg Feet - Custom.vwx) or, if you're on Windows in C:\Users\<your user name>\AppData\Roaming\Nemetschek\Vectorworks\2021\Libraries\Defaults\Custom Part\Leg Feet\Leg Feet - Custom.vwx (or Leg Mounting Plates). Edit the sample fitting geometry and replace the sample geometry with your own geometry. Add drillings if required. make sure you don't ungroup anything. Work inside the groups because there are Vectorworks Record Formats attached to the enclosing groups. If you do it like that you'll be fine. If it does not work, which is to be expected, because it never works the first time around, 😁 , upload what you tried here (the documents from your user folder) and I will have a look. @Stephan Moenninghoff hello I am also testing the demo version of interiorXS. I was looking at how to use my own feet rather than the Hafele/Hettich ones supplied + saw this post. But I do not have the 'Edit/Adapt Fitting Libraries' command in the interior XS menu + I don't have a 'Custom Part' folder in Defaults... Has something changed? Or is this a limitation of the demo version? Or something else...? I have watched the 11 part tutorial series which is excellent but don't remember seeing anything about feet on it... Have also consulted the interiorcad manual but nothing there... Thanks Quote Link to comment
Tom W. Posted May 31, 2023 Share Posted May 31, 2023 (edited) On 5/27/2023 at 11:22 PM, E|FA said: I'm testing the demo version of XS, and trying to get my head around InteriorCad "materials". Are they related in any way to VW "Materials" resources? Is there a way to coordinate them in terms of reporting, graphics, etc? I'm trying to understand interiorcad Materials as well. I notice in my demo version of XS that in some instances where it previously said 'Material' it now says 'Board' which makes it a bit clearer. I don't think there's any coordination with VW Materials. What I'm concerned about is that in your third video @Stephan Moenninghoff you say that if you have interiorxs you can't create your own materials so that means I'm restricted to the supplied defaults...?? Or do I create my own Boards/Materials in the 'Details' section + apply them to all the relevant Construction Groups? Do I have to repeat this for each new cabinet? Or save the first cabinet + adapt it for subsequent ones? What do I do if I want to use a 24mm thick birch plywood board when the thickest offered is 21mm?: Do I have to choose a different material but one which is 25mm (+ be happy with the 1mm difference + incongruous name) then override the texture? Likewise am I restricted to the pre-existing material thicknesses for coverings I want to apply inside + outside? So if I want to apply a 1.3mm thick veneer I can't? I need to settle for 1mm. Thanks to anyone who can point me in the right direction on this! Am I in the ball park @Kevin K...? Edited May 31, 2023 by Tom W. Quote Link to comment
Vectorworks, Inc Employee Stephan Moenninghoff Posted May 31, 2023 Vectorworks, Inc Employee Share Posted May 31, 2023 3 hours ago, Tom W. said: I'm trying to understand interiorcad Materials as well. I notice in my demo version of XS that in some instances where it previously said 'Material' it now says 'Board' which makes it a bit clearer. I don't think there's any coordination with VW Materials. What I'm concerned about is that in your third video @Stephan Moenninghoff you say that if you have interiorxs you can't create your own materials so that means I'm restricted to the supplied defaults...?? Or do I create my own Boards/Materials in the 'Details' section + apply them to all the relevant Construction Groups? Do I have to repeat this for each new cabinet? Or save the first cabinet + adapt it for subsequent ones? What do I do if I want to use a 24mm thick birch plywood board when the thickest offered is 21mm?: Do I have to choose a different material but one which is 25mm (+ be happy with the 1mm difference + incongruous name) then override the texture? Likewise am I restricted to the pre-existing material thicknesses for coverings I want to apply inside + outside? So if I want to apply a 1.3mm thick veneer I can't? I need to settle for 1mm. Thanks to anyone who can point me in the right direction on this! Am I in the ball park @Kevin K...? Just a quick update. I'm too tied up with other stuff but I did create a substantial database of UK-specific materials, corner cabinets, as well as appliances such as fridges, cookers, hobs, sinks etc. These will be included in a future release with interiorcad so stay tuned...! Quote Link to comment
Tom W. Posted May 31, 2023 Share Posted May 31, 2023 4 hours ago, Tom W. said: I don't have a 'Custom Part' folder in Defaults... Ok I've found it in the Application folder but when I open the 'Leg Feet' folder for example + open up the VWX files they don't have any geometry in them...? I was hoping to duplicate one + replace the geometry with my own. Hmmm... What are the .JSON files?? 5 minutes ago, Stephan Moenninghoff said: Just a quick update. I'm too tied up with other stuff but I did create a substantial database of UK-specific materials, corner cabinets, as well as appliances such as fridges, cookers, hobs, sinks etc. These will be included in a future release with interiorcad so stay tuned...! Ok cool but in the meantime, am I correct to say that if for example I want to create some cabinetry that uses a custom board which is 24mm birch plywood faced with 1.3mm Formica ColorCore front + back (= 26.6mm o/a) I basically can only do that properly if I have the full version InteriorCad rather than InteriorXS? Thanks Quote Link to comment
E|FA Posted May 31, 2023 Share Posted May 31, 2023 I have a similar question for XS. Looking to have cabinets cases with 3/4” plywood veneered boards that show plywood fill in section and wood texture in 3d. I’d also like to have other US standard plywood boards. I also like to show solid wood fill on imperial thickness doors. Am I right that using a Solid Wood board for fronts will allow this? Am I missing something? Quote Link to comment
Blinkglitter Posted May 31, 2023 Share Posted May 31, 2023 3 hours ago, Tom W. said: Ok I've found it in the Application folder but when I open the 'Leg Feet' folder for example + open up the VWX files they don't have any geometry in them...? I was hoping to duplicate one + replace the geometry with my own. Hmmm... What are the .JSON files?? There is good guidance on how to do this in the interiorcad manual. http://conf.extragroup.de/im/latest/creating-custom-libraries When you open up the vectorworks file you need to look in the resource manager and you will see and example fitting. Duplicate that and then you can replace the geometry with your own. Don't worry about the .json files. Nb I use the full version so don't know the limitations of XS. 1 Quote Link to comment
Blinkglitter Posted May 31, 2023 Share Posted May 31, 2023 3 hours ago, Tom W. said: Ok cool but in the meantime, am I correct to say that if for example I want to create some cabinetry that uses a custom board which is 24mm birch plywood faced with 1.3mm Formica ColorCore front + back (= 26.6mm o/a) I basically can only do that properly if I have the full version InteriorCad rather than InteriorXS? Thanks To create new boards you need to go to Interiorcad > Master Data > Edit Boards Quote Link to comment
