bugs?
Cut and paste work fine for me in VectorWorks 9 on a Mac. Are you using a Mac or Windows machine? Either way, they should work, and you may want to send details of your bug to bugsubmit@nemetschek.net
You can set the font and size for items in a worksheet using the Format Text command in the worksheet's popup menu.
  • 2 weeks later...
There is a known problem with cut, copy and paste in the worksheet where selected text in the worksheet's formula edit field can not be copied or cut unless at least one drawing object is selected. The same is true for various other edit fields such as the data bar's edit fields.
