Editing records
I make door symbols. I attach them a record default for my schedule. Let's say I want to change the record field/s to all of them at once, including the doors already inserted. How do I do that without getting rid of the door ID? If I change the record fields thru the tool in the edit menu, only the new ones will be affected. If I change the record for each door detaching it and then attaching the new default I loose the ID info. Same if I replace the door symbols with another symbol with the new record. I get the new record but obviously I loose the ID. Pick up attributes tool will change the whole record again.
I cannot select only the doors and change all of them because they are inserted in the walls, not even with the custom selection tool. Any suggestions? Thank you.
