Davide Posted June 8, 2001 Share Posted June 8, 2001 I make door symbols. I attach them a record default for my schedule. Let's say I want to change the record field/s to all of them at once, including the doors already inserted. How do I do that without getting rid of the door ID? If I change the record fields thru the tool in the edit menu, only the new ones will be affected. If I change the record for each door detaching it and then attaching the new default I loose the ID info. Same if I replace the door symbols with another symbol with the new record. I get the new record but obviously I loose the ID. Pick up attributes tool will change the whole record again. I cannot select only the doors and change all of them because they are inserted in the walls, not even with the custom selection tool. Any suggestions? Thank you. Quote Link to comment
