Maarten DE
Placing a symbol instance on a layer
Hi all
I want to create a symbol definition and place an instance of it in the drawing (active layer).
I'm probably missing the obvious here, but why doesn't this work:
	// 1. Create the symbol definition, add a line to it.
	TXString symName = "a unique symbol name";
	VWSymbolDefObj symDef = gSDK->CreateSymbolDefinition(symName);
	symDef.AddObject(gSDK->CreateLine(WorldPt(0, 0), WorldPt(100, 100)));
	// 2. Reset to make the line visible in the symbol definition.
	symDef.ResetObject();
	// 3. Refresh Res Browser to make symbol def visible.
	gSDK->RefreshResourceBrowserResourcesList(true);
	// 4. Place this symbol on the active layer (reset all just to be sure)
	VWSymbolObj symInst(symDef, WorldPt(0,0), 0);
	symInst.ResetObject();
	symInst.SetVisible(true);
	symInst.ResetObjectsVisibility();
	// 5. as a check: get the name of the layer the object is placed on.
	MCObjectHandle* pOutContainerHandle = new MCObjectHandle;
	short* pOutContainerType = new short;
	double* pOutContainerScale = new double;
	symInst.GetContainerInfo(pOutContainerHandle, pOutContainerType, pOutContainerScale);
	VWLayerObj lay(*pOutContainerHandle);
	TXString layName = lay.GetName();
	// The name of the layer is correct, but the symbol is not visible/selectable on the active layer.
Step 1, 2, 3 works fine, the symbol definition is created and visible in the Resource Browser. I can manually drag and drop it in the drawing.
Step 4 and 5 seems to work too, I get the container info (the active layer) but still, I don't see the symbol in the drawing.
Oh, and I'm doing this in CMenu_EventSink::DoInterface();
I believe when creating a symbol from the VWSymbolObj wrapper class it's not properly attached to a container, in your case the active layer.
Try additing it manually after you create the symbol, and before you reset it using "gSDK->AddObjectToContainer"
Hooray, that did the trick indeed 😄 .
I got thrown off because in check 5, I did get the container info (the layer) so I assumed I didn't had to add it another time... Never a boring day with the SDK 🙂 .
Thanks for the help!
I'll also use InsertBefore/InsertAfter. I believe this is also necessary with parametric objects and groups, at least when creating via the object construction.
I believe that these objects add to the document tree after the termination node, so even though the parent is correct, they are not actually in the visible document list.
As a side note, I believe that instead of creating new pointers, you can simply create a variable instance and pass the address. i.e.
MCObjectHandle hOutObject = nullptr;
symInst.GetContainerInfo( &hOutObject...
That lets your memory be managed by the scope, which is a bit simpler.
I'm using gSDK->AddObjectToContainer() now and it seems to work fine. But I'll keep that InsertBefore/InsertAfter in mind whenever something strange pops up on the way, thanks for the tip!
And you're right about the nullptr, the function will already create a new instance. I've been out of the whole computer/programming/Vectorworks world for several years so it's all a bit rusty, but it's slowly coming back 🙂 .
