Exterior Wall Dimensioner
I am having problems with the Exterior Wall Dimensioner.
I imported an 8.5.2 file and had no luck at all with trying to get it to work. Absolutely nothing happend.
I created a new file in VA9 containing just 4 exterior walls (class: wall-ext-frame). EWD placed two unassociated 0' dimensions off to the side.
In both cases the dialog box "Dimension the walls on this layer" had no choices at all.
Whatzup with this?
G4 AGP, 448MB VM off, 400MHZ, running VA9/RW9
Ed Dunn
Solar Design &
Construction
Flagstaff, AZ
  • 3 weeks later...
Interesting that no one ever responded to this. Yesterday I tried again. This time I applied the standard VWA classes to the walls and it worked. It isn't perfect but it will be a feature that will save a great deal of time.
Ed Dunn
Solar Design &
Construction
Flagstaff, AZ
