T. A. Brown Posted May 7, 2001 Share Posted May 7, 2001 I may just be missing something really simple, but I like to work with a black background and when I print a drawing to a black and white laser printer that contains solid fills, they do not appear as solid black objects. I only get the outline of the shape. If I change the screens background colour to white, it prints as intended. Anyone else experience this?. P.S. I really miss the command T for trim. Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted May 15, 2001 Vectorworks, Inc Employee Share Posted May 15, 2001 I may be missing something here. Are you wanting the black background to print? Quote Link to comment
T. A. Brown Posted May 16, 2001 Author Share Posted May 16, 2001 No. I don't want to print the black background. My problem is that I usually like to work with a black screen background but when I print a drawing that has walls for example, filled with solid hatching only the outline of the walls prints without the solid hatching that I have applied which should appear as solid black. If I change the screen background to white and then print I get the desired result. The walls now are filled solid black. I am using an HP 4MV printer and I did not have this problem with 8.5.2. Quote Link to comment
