Path extrude and Solid Boolean not working
Hi Endre,
the problem is not with the Solid Boolean here, but with the type of objects you are trying to merge.
The node "Path Extrude" produces an object called "Extrude Along Path" which is a PlugInObject. PIOs cannot be used for boolean operations.
Produce extrusions with the node "Extrude" and then try merging those with the node "Solid Boolean".
Good luck.
