2 worksheet questions
toonau69
I am creating worksheets that contain Height and Spread values and have 2 querys.
Query 1. The Height is appearing OK...thanks to your help on my last issue [smile]
However I am expecting the Spread value on the Define Plant dialog to be displayed but am seeing the Spread that is displayed on the Set Plant Tool Options.
Select the Plant Settings button and the Spread that is displayed in the Set Default Plant Tool Options dialog is the one populated in the worksheet.
FYI the header used is:
='plant record'.spread
The end game for me is to show a worksheet with the spread and height from the Define Plant dialog.
Query 2. Ideally i would prefer to show the height and spread ranges from the Plant Reference DB. Can you help with the worksheet header values for these attributes?
thanks again for your help
toonie
1. The spread that is displayed will be the actual drawn spread of the plant (which as you have seen, is what the plant tool sees.) If you don't change the default for the tool when you choose a plant from your catalog, this value should match the value in the plant definition.
2. The values for the stored height and spread ranges are as follows:
Height
01: <=12in
02: >12 - 18in
03: >18 - 24in
04: >24 - 30in
05: >30in - 3ft
06: >3 - 5ft
07: >5 - 10ft
08: >10 - 15ft
09: >15 - 35ft
10: >35 - 50ft
11: >50 - 80ft
12: >80 - 100ft
13: >100ft
Spread
01: <=12in
02: >12 - 24in
03: >24 - 36in
04: >36in - 4ft
05: >4 - 7ft
06: >7 - 12ft
07: >12 - 20ft
08: >20 - 35ft
09: >35ft
The only way I know of to return these "verbose" values from the stored integer values is to use a nested IF() function.
