toonau69 0 Posted January 30, 2005 I am creating worksheets that contain Height and Spread values and have 2 querys. Query 1. The Height is appearing OK...thanks to your help on my last issue [smile] However I am expecting the Spread value on the Define Plant dialog to be displayed but am seeing the Spread that is displayed on the Set Plant Tool Options. Select the Plant Settings button and the Spread that is displayed in the Set Default Plant Tool Options dialog is the one populated in the worksheet. FYI the header used is: ='plant record'.spread The end game for me is to show a worksheet with the spread and height from the Define Plant dialog. Query 2. Ideally i would prefer to show the height and spread ranges from the Plant Reference DB. Can you help with the worksheet header values for these attributes? thanks again for your help toonie Quote Share this post Link to post
Robert Anderson 128 Posted January 31, 2005 1. The spread that is displayed will be the actual drawn spread of the plant (which as you have seen, is what the plant tool sees.) If you don't change the default for the tool when you choose a plant from your catalog, this value should match the value in the plant definition. 2. The values for the stored height and spread ranges are as follows: Height 01: <=12in 02: >12 - 18in 03: >18 - 24in 04: >24 - 30in 05: >30in - 3ft 06: >3 - 5ft 07: >5 - 10ft 08: >10 - 15ft 09: >15 - 35ft 10: >35 - 50ft 11: >50 - 80ft 12: >80 - 100ft 13: >100ft Spread 01: <=12in 02: >12 - 24in 03: >24 - 36in 04: >36in - 4ft 05: >4 - 7ft 06: >7 - 12ft 07: >12 - 20ft 08: >20 - 35ft 09: >35ft The only way I know of to return these "verbose" values from the stored integer values is to use a nested IF() function. Quote Share this post Link to post
toonau69 0 Posted January 31, 2005 cheers, I will need to investigate this further. toonie Quote Share this post Link to post
