str
Slab component visibile in top/plan even if class is not visible
Hello,
In Top/Plan view - both in DL and in SLVP - slab components are visibile even when component class is set to invisible.
In 3d views everything seems to work as expected. Is this working as designed?
I am running VW2021 SP2 on Mac OS Big Sur. Attached both video & vwx file. Thanks in advance for any help!
VW2021 - slab component.vwx
Edited by str
3 answers to this question
I am not seeing what I think you are trying to point out when I open the file in VW2021SP2 here.
What service pack are your running?
Have you restarted VW? Have you restarted the computer?
Thanks @Pat Stanford for your kind and prompt reply. Yes I did.
Here running 2021 SP2 (Build 574483) localized italian on macOS 11.1 (20C69).
My target: having a top/plan view in a SLVP where the "lean concrete" component is not showing (lean concrete class "not visible") while I need to have it correctly rendered/visibile in model&sections.
Edited by str
In top plan view the components aren’t visible really. You see a graphic representation of the slab with all visible elements drawn in top view with the attributes as indicated in the style, not the components.
If you want to get a correct drawing of a slab, for a lot of reasons, you need to draw 2 slabs: one with the constructive floor, spreading over the whole surface of the building. And a bunch of “finish” slabs per space. That way you can have separate floor finish types per room.
And it will also allow you to do as you like.
