hollister design Studio Posted December 17, 2020 Share Posted December 17, 2020 Made a hardscape and set it in hardscape settings menu as 'Boundary' on configure tab and 'texture bed modifier' on the Draw 3D tab. It isn't going to the surface and in 2d plan view has a red/white update outline. Site doesn't require an update (did it anyway) and I don't see any "update" button on hardscape OIP What is VW asking me to do? Quote Link to comment
J. Wallace Posted December 17, 2020 Share Posted December 17, 2020 @hollister design Studio whenever you add a texture bed or other site modifier you will need to update your site model which is what the red/white outline is indicating. 1 Quote Link to comment
hollister design Studio Posted December 17, 2020 Author Share Posted December 17, 2020 13 hours ago, J. Wallace said: @hollister design Studio whenever you add a texture bed or other site modifier you will need to update your site model which is what the red/white outline is indicating. Thanks J. Wallace - but that's not what's happening here. I've update the site model. Also the site model is NOT outlined in red/white nor is the "update" button in the OIP red. Updating the site model doesn't send the hardscape to the surface nor does it get rid of the "update' outline. Landscape areas have a "site model layer" entry box in the OIP but hardscapes set to Slab do not - is that setting somewhere else? I've also had an 'Aligned slab modifier" hardscape outlined in red/white. The site model in this case was not outlined either, and updating the site model didn't remove the red/white outline from the hardscape. I eventually just deleted the hardscape as I could not get rid of the outline. Quote Link to comment
J. Wallace Posted December 18, 2020 Share Posted December 18, 2020 7 hours ago, hollister design Studio said: Thanks J. Wallace - but that's not what's happening here. I've update the site model. Also the site model is NOT outlined in red/white nor is the "update" button in the OIP red. Updating the site model doesn't send the hardscape to the surface nor does it get rid of the "update' outline. I had some challenges with hardscape objects in 2019 but these seemed to diminish with the current 2021. I see that is what you are running. You might want to post the file if you can. I usually use pads and place hardscape items on top of these. 1 Quote Link to comment
