David Poiron 33 Posted December 16, 2020 It would be nice to have multiline text in space objects so longer names do not bleed off the edges of the object. Quote Share this post Link to post
0 michaelk 508 Posted December 16, 2020 This is one of the many reasons I've stopped using space labels and just use Data Tags. If your signature is out of date and you have 2020 or 2021, you'll find data tags much easier to use and much more graphically flexible. 1 Quote Share this post Link to post
0 David Poiron 33 Posted December 19, 2020 Strangely enough we have been using a data tag for space objects for reflected ceiling plans, as we need the space label location to change for these drawings. I had a thought that if I had multiline text, my room number which is above the text would need to move upwards automatically. I thought to use a coincident constraint between the two text objects, but this tool does not seem to work on the side, top or bottom centres of text objects, or the centre of the text objects. Do you have any suggestions on how to address this apparent shortcoming? Quote Share this post Link to post
