AlHanson
Get Object Texture
I'm attempting to pull the name or handle of the Texture that is assigned to an object and I can't come up with a working method. Get Texture Set (vs.GetTextureSet) looks like it should do this, but I can't get it to return anything beyond a 0 int. Any insight?
If anybody winds up here down the line, I finally figured this out. The command is vs.GetTextureRef/vs.GetTextureRefN. This was one of the first things I was trying, however everything I was testing on was a Mesh object, in which case  you cannot use Overall for the part number. As I'm finding now, meshes us Part ID 4 ('Top of Extrude or Sweep'). Once I stumbled on that everything started working just dandy. Hope that helps somebody down the line!
