Rishie
How to align wall's surface hatch while generating exterior elevation
I'm finding a way to align wall hatch but with no luck.
Can anyone here can help me with it?
Thanks,
Rishie
At the bottom of the Render tab of the OIP of every Wall object there is a toggle called 'Use World Z for Origin'.   Turn this on for all your walls.
If you need a unique alignment you should be able to use the Attribute Mapping Tool.
Hey @Joe-SA. It didn't know about this setting. Good to know! Thanks.
Do you also know if there is a way to have wall textures use the world z origin on insertion? When I create a new wall with the wall tool the "Use world Z for origin" option is unchecked.
Cheers
Edit:
Hmm just noticed that the hatches are aligned in the design layer but not in a section viewport. See what happens when I jump from the viewport to edit section in place in attached short vid. I posted about this in a separate thread but hoped aligning to world z would sort this.
Edited by Boh
