Aqueous
Imported 2d dxf files
Is there any way of getting VW to read the content of text boxes to a worksheet? We have a couple of large imported survey files where the level data is not linked to loci and would like to convert to 3d loci.
The only way to do this is through using VectorScript. It's a relatively simple matter (if you understand VS) to set up a script to do this. Maybe there's a VW user in your area who can help you?
Robert,
Thanks for your reply. I did check with contacts in this area but no one was able to help. I need to understand more about using scripts as I have only very limited experience. I ended up recreating the level data by placing stake objects over each and assigning the appropriate level value. This was probably better in the long run as it ensured that the positioning followed the original loci rather than the text boxes.
