HMP Posted March 27, 2001 Share Posted March 27, 2001 How do you set stairs in plan so that they go down in section? Even though I set them up with "down" arrows and everything I still end up with steps going up from whatever floor I'm putting the on. Quote Link to comment
HMP Posted April 23, 2001 Author Share Posted April 23, 2001 quote: Originally posted by HMP: How do you set stairs in plan so that they go down in section? Even though I set them up with "down" arrows and everything I still end up with steps going up from whatever floor I'm putting the on. I've found the answer to this in the manual...and a dummy stair that goes up and click the "not 3d" option in the object info. Quote Link to comment
jfmarch Posted April 25, 2001 Share Posted April 25, 2001 I beleive this is a VW default. What I do is after inserting a stair object, I flip to 3D mode to see it's configuration. If its wrong, I simply move it down with the 3D move dialog box. The arrows don't control the stair layout, they are simply graphics. In this way, when you cut a section, the stair will be in the right place. Hope this helps. ------------------ Jim McAuliffe, RA Quote Link to comment
