I don't really understand what is happening with the slabs at Vectorworks. I have a large project where I drew all my slabs and attached them to walls. I then have to do some operations such as cutting out parts where tubes, beams and stairs are. I then see that the plate is no longer linked to my walls. If I then double click on my slab and go to the outline, the slab is gone. It is also on a level that is completely wrong, but in a section it is good, but you can no longer edit it.It is very frustrating to draw the plate every time and then later in your drawing after x number of operations to further determine that the slab has disappeared for the umpteenth time. Is this a known problem and how can it be solved?
