alfresco 0 Posted November 20, 2020 I am using VW2021. I am working on a landscape plan. I have created a number of Landscape Areas and would like to report area as specified on the plan. I have the different type of landscape areas identified by class. Individual areas have been given a name identifying each area. The associated worksheet is not reporting all area?. There are a number of landscape areas not calculated in the worksheet? All areas are closed and have an area in the O.I.P. Why is the worksheet not updating to report all areas? Thanks lm Quote Share this post Link to post
Pat Stanford 1,425 Posted November 20, 2020 Open the Worksheet for editing. From the Worksheet View menu, make sure Database Headers is checked. This should show a row above the subrows that contains the formulas. (eg 3, not 3.1, 3.2, etc.) Right click on the Row number of the Database Header row and choose Edit Criteria. Take a look at the criteria and see if there is something there that is blocking the areas from displaying. If you can't figure it out, post a screen shot here of the Criteria dialog box and we can help explain what it is doing. Quote Share this post Link to post
Tony Kostreski 101 Posted November 20, 2020 Hey @alfresco, Let me know if this image helps. You can edit the criteria of each database header to select a class. Landscape areas are special in which you can pull projected area and surface area if a site model exists. Quote Share this post Link to post
alfresco 0 Posted November 20, 2020 Thank you gentlemen I will take another look. Quote Share this post Link to post
alfresco 0 Posted November 20, 2020 Thank you gentlemen I will take another look. 2020Method.vwx Quote Share this post Link to post
