jnr Posted June 26, 2000 Share Posted June 26, 2000 Robert: I'm reposting this to make sure you see this. Thank you for looking into this problem. I applied your recommendation to reduce the font size of the menu. The font is set to 7pt Arial. This allows angles, tees and wide flange menus to open properly. Unfortunately I now need to keep a magnifying glass next to my 21" monitor to read the sizes! The desktop is set at 1280x1024. It would appear there needs to be a better way to solve this problem. Could the menu be reduced in some way, say include just the more popular sizes of steel and allow less common to be selected as a custom shape? Thanks Quote Link to comment
Marc Pitman Posted June 27, 2000 Share Posted June 27, 2000 I have to agree. I had to turn the font down to the same size, 7 pt arial, but that is not a good solution since text is barely readable at that size. There is plenty of room for a much larger drop down box or use a scroll down menu. Nemetschek, please fix this annoying problem. Quote Link to comment
jnr Posted June 28, 2000 Author Share Posted June 28, 2000 Second the motion. Boys, lets get it fixed. . . Quote Link to comment
