Thomas Ames Posted June 1, 2000 Share Posted June 1, 2000 I'm in CD volume 2, chapters 2 & 3 and am noticing that the rectangle tool produces 8 handles. As I try to follow along with VW, I only get 4 handles. Also with the CD lessons, VW Setup Assistant offers a Perspective Sheet. I don't seem to find this in VW. Are these features just not important? Am I doing something wrong? Quote Link to comment
Guest Posted June 1, 2000 Share Posted June 1, 2000 quote: Originally posted by Thomas Ames: I'm in CD volume 2, chapters 2 & 3 and am noticing that the rectangle tool produces 8 handles. As I try to follow along with VW, I only get 4 handles. Go to VectorWorks Preferences and click the checkbox labelled "Eight Selection Handles". Cheers, Caleb Strockbine caleb@diehlgraphsoft.com Quote Link to comment
Guest Posted June 1, 2000 Share Posted June 1, 2000 You must set in your VectorWorks Preferences to have 8 handle selection, otherwise you will only have 4. Once you set this it will remain so until you change it. The perspective sheet is offered during the AEC Project Setup. If you do not run the project setup you must create your own sheet and set the view to perspective in order to achieve this. If you have any questions, please call Technical Support with your registered Serial Number and we will be glad to walk you through this. ------------------ Brian O Diehl Graphsoft, Inc. Technical Support Quote Link to comment
