d.kocieniewski Posted May 24, 2000 Share Posted May 24, 2000 I'm using Architect and VW-8.5.2 and I discovered that some of the Marvin windows I'd used recently from the Object Library that came w/ Architect are no longer editable. Instead of appearing in the info pallette as a complex window [as it originally had] w/ all the many fields to edit for size,frame, mullions, etc.it appears as a "CUSTOM OBJECT in wall" and all I can edit is the position, height, and flip - in fact none of the other fields even appear. When I try to get another of the same window from the browser it has all of the fields and is editable. What gives? The only thing I can think of is that i had originallly created the document in 8.5.1 then updated it when I received Architect [icluding replacing some earlier windows with the new Marvins] and then later opened it up and modified it in 8.5.2. I had also made some modifications to the Marvins upon use - just adding some mullions. I'd really hate to have to replace all these window objects again. Quote Link to comment
Lyndsey Ferguson Posted May 25, 2000 Share Posted May 25, 2000 quote: Originally posted by d.kocieniewski: I'm using Architect and VW-8.5.2 and I discovered that some of the Marvin windows I'd used recently from the Object Library that came w/ Architect are no longer editable. Instead of appearing in the info pallette as a complex window [as it originally had] w/ all the many fields to edit for size,frame, mullions, etc.it appears as a "CUSTOM OBJECT in wall" and all I can edit is the position, height, and flip - in fact none of the other fields even appear. When I try to get another of the same window from the browser it has all of the fields and is editable. What gives? The only thing I can think of is that i had originallly created the document in 8.5.1 then updated it when I received Architect [icluding replacing some earlier windows with the new Marvins] and then later opened it up and modified it in 8.5.2. I had also made some modifications to the Marvins upon use - just adding some mullions. I'd really hate to have to replace all these window objects again. Well there shouldn't be any problem with opening a file created with ARCHITECT 1.0 in ARCHITECT 1.0.1. I found that it did work fine for me. It sounds to me like the window plug-in record somehow got destroyed and the pre-existing Marvin windows that you placed previously no longer point to the window plug-in so they can no longer act like the plug-ins. There may be something we can do if you can get in touch with Tech support and give them a copy of your file for me to examine. www.diehlgraphsoft.com/support/contact.html Quote Link to comment
