Woorksheet question
The * to mean any characters does not seem to work with Layers.
You could use a criteria of  Class = 'Class*' to get all classes that start with the word Class, but it does not work for Layers.
If you have a lot of Layers that start with 4385, you might want to look into using the Database By Script option to generate the database. If you only have a few, you will have to manually select each layer into the criteria. They will be OR'd together to get what you want.
((Type = 'Wall') & ((Layer='4385-1') | (Layer='4385-2) | (Layer='4385-3))). where the vertical bar is a logical OR function.
Ask again if you want to pursue the Database by Script option.
