Class Dropdown in Object Info
On several occasions spanning several MC/Vectorworks releases I have had the dropdown for classes in Object Info stop responding. This same drawing behaves normally when loaded into a different machine. Other drawings on the original machine behave as they should. I have had to delete the drawing and load a backup to continue. This has happened in different drawings. I have not exceeded the max # of classes. ??
George:
This is a situation we would need to talk with you about.
Please contact Technical Support at (410)290-5114 so that we may get more details and attempt to duplicate the issue.
Thanks in advance.
