FRED JOHNSON Posted March 14, 2000 Share Posted March 14, 2000 Does VWA automatically assign lineweights to objects, if so, can these be changed on the fly without screwing things up? Quote Link to comment
amfethes Posted March 15, 2000 Share Posted March 15, 2000 quote: Originally posted by FRED JOHNSON: Does VWA automatically assign lineweights to objects, if so, can these be changed on the fly without screwing things up? If you use the VA Setup it will assign LW via the pre-set class structure. You can change the LW of any singular object (or selected objects) via the attribute pallette. Alternatively you can change the LW by changing the class attributes and every object with that class would change. I recommend the latter to avoid screwing things up (which I do often <grin> ). ------------------ Quote Link to comment
FRED JOHNSON Posted March 17, 2000 Author Share Posted March 17, 2000 Thanks, I feel sort of stupid for asking. fjjRA Quote Link to comment
