Bill Posted March 11, 2000 Share Posted March 11, 2000 I used the Task Manager to setup things so I could draw the footings in the Foundation Plan sheet. Then I used Task Manage to switch to the Floor Plan-1 sheet. This sheet does not include the Mod-Foundation layer so I can't see my foundation in order to draw the first floor walls. Question: - Should I be able to see the foundation in order to draw the first floor walls or am I using the sheets incorrectly. Quote Link to comment
Guest Posted March 22, 2000 Share Posted March 22, 2000 Please check the visability in your Floorplan 1 Sheet. You may not have your footings visible and therefore will not see them. If you are still having problems, please contatct technical support directly at (410)290-5114 (tel), (410)290-8050 (fax) or at tech@diehlgraphsoft.com with all information that you can provide, including your registered serial number and a contact number. Quote Link to comment
Wilmer Gingerich Posted December 16, 2000 Share Posted December 16, 2000 quote: Originally posted by wfosbury: I used the Task Manager to setup things so I could draw the footings in the Foundation Plan sheet. Then I used Task Manage to switch to the Floor Plan-1 sheet. This sheet does not include the Mod-Foundation layer so I can't see my foundation in order to draw the first floor walls. Question: - Should I be able to see the foundation in order to draw the first floor walls or am I using the sheets incorrectly. Just a suggestion; Make yourself an out line to reference all walls, footings, etc. to,select them,then go to Edit/Guides/Make Guides. That way you can turn them on or off no matter where you are in your drawing. Hope this helps... Wilmer Gingerich Quote Link to comment
