Bill Posted March 11, 2000 Share Posted March 11, 2000 Hi, this is Bill, I used File, New and selected VA Setup Assistant to create a document. One of the sheets I had it create was the Elevations-1 sheet which is a layer link. This particular sheet shows four views of the drawing. In trying to figure out how that was accomplished, I checked: - Vectorworks User's Guide index looking at - Elevation - 12-1, 14-20 - Layer Link - 3-12 Question: - How can I get multiple views to show up in other drawings that are not setup via Architect Setup? Quote Link to comment
RThib Posted March 21, 2000 Share Posted March 21, 2000 I found a technique for this on a Tips and Tricks page at www.zeta.org.au/~jbcarr/TandT.htm. 1. Create a 3D model on as many layers as required and setup the layers with correct Z values. 2. Create a single new layer for Linking, set it to Top/Plan view and link it back to as many 3D layers as required. 3. Choose Unlock from the File menu then Group from the Organize menu. Now reposition the Group in say the top left corner of the sheet and choose Copy. 4. Paste three times, each time repositioning the Pasted Group to a different part of the sheet. You now have four identical models on the sheet. 5. Now comes the interesting bit. Rotate three of the four models 90, 180, and 270 degrees respectively, select the top two models and set the view to Front. 6. Drag the two selected views from on top of the other views and you have four elevational views on the one layer. These can be repositioned using Snap To Object with the SmartCursor, to align them correctly. Quote Link to comment
