IMPORTING DWG ISSUES
Matt Hagen
4 answers to this question
Hello Matt,
We were able to see why the last char from the text is imported not as expected - the formatting is at the end of the DWG text, but it is actually not used for any of the text chars. The formatting has been wrongly added there - the DWG itself has not been originally created inside AutoCAD and actually such formatting cannot be added from inside there. AutoCAD however checks the case properly and shows the text correctly, while we have not expected such a case - right now, due to a failure to find a char, to which to apply it, we just apply it to the last char. An engineer worked on this issue and proposed a fix, which will be included in a future Vectorworks release/service pack. Until then, please use the attached document, which we created for you.
Thank you for finding this problem and reporting it!
Best regards,
Nina
BLK 27 - Ground Floor v2020.vwx BLK 27 - Ground Floor.vwx
  • Like 3
