Fixtures in schematic view are labeled as lighting pipe objects
cessna310
In a file a created a while ago all of the fixtures in my schematic view now show up a Lighting Pipe objects in the OIP. If I try to recreate the position as a schematic view just the pipe appears but none of the fixtures that are on it. All the fixtures behave as normal in the non-schematic view. And yes the position on the Lighting Device matches the pipe it's on.
There is no doubt some mode I turned on that is causing this but I don't know what it might be. Thoughts?
Can you right click the lighting device and select assign to rigging object, then select its respective pipe?
Also the Lighting Devices position name must exactly match the name of the hanging position. If you are not using hanging position I would recommend keeping the position field blank.
