WANA 6 Posted November 4, 2020 See attached three images of the same geometry - two roof faces and one roof object with two different textures on for reference. The images are in Top/Plan, Hidden Line and Open GL rendering mode. Can anyone tell me why on earth in Top/Plan the surface hatch won't behave in the same way as in the other two modes? The other two modes show clearly that the geometry, texture and surface hatch is working how I want it to so it just baffles me and messes with our viewports which would usually be in Top/Plan. Any help gratefully received before I pull what remains of my greying hair out... Quote Share this post Link to post
Tom W. 151 Posted November 4, 2020 A surface hatch only displays in 3D. In OpenGL you see the texture; in Hidden Line you see the surface hatch. The surface hatch is like a black + white line version of the texture. Top/Plan is a 2D view so here you see whatever 2D attributes you've assigned to the objects. In your case hatch fills. So in your images the top row is Top/Plan view (2D) + the other two rows are Top View (3D). What's confusing is the surface hatch displayed on the middle left hand object: you should check the paving texture you used on the bottom LH object + see what surface hatch is assigned to it as it looks like you need to change it from the clay tile one to a brick one. If i've understood your images correctly 1 Quote Share this post Link to post
WANA 6 Posted November 10, 2020 Hi tom Thanks for that - makes perfect sense. Follow up question, without showing plan viewports in 3D I assume there is no way of getting those roof hatches to show correctly without doing a bit of invisible mending within the viewports? PS The left object is confusing things as its showing material by component on a roof face and the component didn't match... I rushed out an example but you got the gist and helped anyway! Quote Share this post Link to post
Tom W. 151 Posted November 10, 2020 Hi @WANA what you can do is start off with a Top/Plan VP then stack a second one on top: the second VP would be in Hidden Line + just have the roofs on it. So the roofs will display with the hatches but everything else will be 2D. 1 Quote Share this post Link to post
Christiaan 861 Posted November 12, 2020 This is one of those little things that has an annoying but easy workaround, so it never gets a fix. But there is another way around this, which is to not use Top/Plan view and instead opt for a Horizontal Section. That way you can utilise the surface hatch in you roof texture. Quote Share this post Link to post
