DBLD 11 Posted November 4, 2020 Hi, We have created a template file that contains a lot of resources that we regularly use. We also from time to time need to share a project file with collaborators but we don't want to share the extra resources associated in the file. Is there a way to do this? Cheers, Dan Quote Share this post Link to post
markdd 699 Posted November 4, 2020 The best way to remove resources from a file is to use the Purge Command. However, the resources for that file will not be recoverable, so you need to use this command with some caution. Personally I am not a fan of Template files apart from storing document preferences such as Unit setup as well as Dimension styles. I use Workgroup Library folders to bring in all my resources. I also use a file that holds all my Classes and Layers, which I import as necessary. Quote Share this post Link to post
DBLD 11 Posted November 4, 2020 Thanks Mark! That gives me something to think about. Cheers Quote Share this post Link to post
