I wish Architect can do:
Beside other wishes I posted in "General Discusion/Undo comand" here is some other concerned only for Architect:
-To see multi composed walls as they realy are eg.- 8"CMU Block + 4" Metal Studs/with insulation + 5/8" DryWall on it. Like the small picture you made on the back of the box.
-I hoped for Roof Framer function to be realy what you should need, at leest to see beams, joist and other parts of the roof when program is not able to calculate them for you, based on the type of the roof and loads on it.
-more details for steel work, Plug-in like Microstation's GeoPak Rebar
This topic is now closed to further replies.
