doug shaffer Posted January 24, 2000 Share Posted January 24, 2000 Hi - How do I turn off the threshold lines that appear at doors when they are placed using VW Architect? thanks ------------------ d. s h a f f e r a r c h i t e c t k c m o u s a Quote Link to comment
Guest Posted January 25, 2000 Share Posted January 25, 2000 If you are referring to the two lines that appear across the doorway when you drag-and-drop from the libraries, they are "head jamb" lines that will disappear as soon as you regenerate the door in the wall, as you would for adding jamb depth and trim. Try clicking on the checkbox next to the words "installation settings." The lines should go away. For further infomation please refer to your user manual in section 10-10 referring to object placement. Quote Link to comment
