We are giving project sharing another try. So far - so OK.
One issue is that we have room tags using the new data tag tool that are connected to spaces. Even simply moving the tag in a viewport seems to require that you have the space checked out. Why? It is problematic if you have somebody working on notations while somebody else is tweaking the model. It seems that the location of the tag in the viewport should not require the checkout of the root object. Really all data should not require checkout. If I needed to change a tag - I should be able to do that without checking out the object.
Tom Klaber
0 answers to this question
