Shubham Joshi 1 Posted October 27, 2020 Hello Everyone As I debug a Tester Module plug-in is developed in vectorworks but during debugging a break point is not hitting. Thank you Quote Share this post Link to post
Nicolas Goutte 79 Posted October 27, 2020 Mostly it happens when you are not debugging what you think you are debugging. (The exakt version of what you start differs from what is in your IDE (Xcode or Visual Studio) Quote Share this post Link to post
Shubham Joshi 1 Posted October 27, 2020 @Nicolas Goutte Hello Sir, Thank you for your reply. Sir, When I am in debug mode and start debugging then breakpoint gets hit but get exception error. Then I change it to release and start debugging then this issue is comming. Sir, I am using Vectorworks 2021 and Visual Studio 2017. Thanks and regards. Quote Share this post Link to post
Nicolas Goutte 79 Posted October 27, 2020 (edited) You are sure to have the Release plug-ins seen by VW. And only that one, not both. Edited October 27, 2020 by Nicolas Goutte Quote Share this post Link to post
Nicolas Goutte 79 Posted October 27, 2020 Also the problem of releasing a Release target is that the compiler is allow to change the code. So it could happen that the line where you set the breakpoint is not in the generated plug-ins anymore, so that the debugger does not stop. Quote Share this post Link to post
JBenghiat 333 Posted October 28, 2020 If you haven’t already, use this as a guide to setting up the IDE: https://developer.vectorworks.net/index.php/SDK:Debugging_SDK_Plugins You are actually running a release configuration with access to debugging symbols. Where in the code did you place the break? Your problem may also be that Vectorworks simply isn’t calling the code containing the break instruction. 1 Quote Share this post Link to post
