zoeageorg Posted October 26, 2020 Share Posted October 26, 2020 Wall timber framing AEC tool problem - not aligned with windows when i run framing when internal walls are joined to the external walls, i get a strange problem that makes the frame (studs, header and sole plates) go at an angle and stick out of the wall when i unjoin these and run the tool, the studs do not match up with my external openings also does anyone know if i delete or add any extra studs if the worksheets will update Quote Link to comment
