Mark Aceto 453 Posted October 25, 2020 It seems that Schematic View will only show rigging objects. First of all, is that correct? Does Plot & Model view still exist somewhere? I can't find it in the workspace editor... Quote Share this post Link to post
markdd 764 Posted October 25, 2020 Not necessarily true. watch this webinar a did for Vectorworks last month! 1 1 Quote Share this post Link to post
Peter Neufeld 240 Posted October 25, 2020 Dear Mark, That's a totally brilliant webinar, thanks for doing it. Cheers, Peter 1 Quote Share this post Link to post
Mark Aceto 453 Posted October 26, 2020 @markdd I watched it live, and plan on rewatching numerous times, but I’m getting a warning about rigging objects, and also just literally can’t see the stage objects (decks and plugs) in the schematic view. Is it only rigging and lighting? Is there a rough min marker in your webinar that explains how to accomplish this? Oh crap, it’s the top vs front view thing isn’t it? Quote Share this post Link to post
Mark Aceto 453 Posted October 26, 2020 (edited) I’m trying to rotate stage objects 30° off vertical: 7 hours ago, Mark Aceto said: Trying to model a roof surface / array with the following parameters: Parametric editing 48x96x4 "tile" (sheet of some outdoor weather rated material) Outer finish component w/ "concrete" material Core / load bearing component w/ a material Insulation component w/ a material 48x96x4 "tile" attaches to metal framing 2x6 profile 48x48 frame (grid) Frame aligns / flush with all edges including plugs along the "gable" side of the structure Mitered hip with no gaps I'm too lazy to plate this up right now, so in the attached screenshot: The concrete / Tyvek textured pyramid is 2 joined roof faces The untextured pyramid is 2 surface arrays I'm tempted to do a schematic view of stage deck / plug objects, and fake the mitered hip, but I'm afraid (literally shaking in my boots) this may turn into my first Marionette project... Exterior view: Interior view: Edited October 26, 2020 by Mark Aceto Quote Share this post Link to post
markdd 764 Posted October 26, 2020 8 hours ago, Mark Aceto said: Is there a rough min marker in your webinar that explains how to accomplish this? Hi Mark Only Rigging objects and geometry within Hanging Positions will respond to the hanging position command. Any items that can be attached to either of these such as Speakers, Drape objects, Load objects, Motors and of course Lighting devices will be shown. To my knowledge staging like the Stage Deck tools cannot be be added to schematic views. Sadly the only way to show a decking object at any angle other than flat on the ground is to ungroup it. This will mean that all the plug-in functionality will be lost. The Create Plot and Model View command is in the Workspace Editor last time I looked, but the staging plug-ins will not rotate inside a viewport. @C. Andrew Dunning Now, if the Stage deck tools could have a similar "3D only" function as the Truss objects, then they could probably be rotated any way you like. 1 Quote Share this post Link to post
C. Andrew Dunning 195 Posted October 26, 2020 20 hours ago, Mark Aceto said: Does Plot & Model view still exist somewhere? I can't find it in the workspace editor... Whether P&M exists or not, you can accomplish the same thing (w. a lot more control) using Design Layer ViewPorts. Quote Share this post Link to post
Mark Aceto 453 Posted October 26, 2020 @markdd thanks! I forgot about the word "Create" so I was searching scanning for "plot". I'm sure search functionality has already been requested in the workspace editor... @C. Andrew Dunning I tried rotating a DLVP with stage objects but I get the ole "hybrid objects can only be rotated... " error message. Maybe I'm missing something? File attached. Tilted Stage v01.vwx Quote Share this post Link to post
C. Andrew Dunning 195 Posted October 26, 2020 3 minutes ago, Mark Aceto said: I tried rotating a DLVP with stage objects but I get the ole "hybrid objects can only be rotated... " error message. Maybe I'm missing something? You have to have at least one Lighting Device in the "source" Design Layer. Insert a "Dummy" fixture and hide it. Quote Share this post Link to post
Mark Aceto 453 Posted October 26, 2020 (edited) With Create Plot & Model View, I get the following error message, and then the stage objects are removed (same behavior as Schematic View): Edited October 26, 2020 by Mark Aceto Quote Share this post Link to post
Mark Aceto 453 Posted October 26, 2020 1 minute ago, C. Andrew Dunning said: You have to have at least one Lighting Device in the "source" Design Layer. Insert a "Dummy" fixture and hide it. Just tried that with DLVP, and I get the same error message as SV and CPMV. VW is very unhappy with my choices... Quote Share this post Link to post
markdd 764 Posted October 26, 2020 Just now, C. Andrew Dunning said: You have to have at least one Lighting Device in the "source" Design Layer. Insert a "Dummy" fixture and hide it. I'm afraid that function does not work any more...... more's the pity.... Quote Share this post Link to post
C. Andrew Dunning 195 Posted October 26, 2020 51 minutes ago, markdd said: I'm afraid that function does not work any more...... more's the pity.... You might want to double-check that. I just created a quick raked DLVP. Works as-expected. Now...what does NOT work is fixtures' auto-focusing from within DLVPs. DLVP_Demo.vwx 1 Quote Share this post Link to post
Mark Aceto 453 Posted October 26, 2020 @C. Andrew Dunning I'm all good with truss and lights (and 3D objects that aren't hybrid). It only seems to be an issue with stage objects (which I guess I've never tried before) or other hybrid objects that aren't lights. Quote Share this post Link to post
Mark Aceto 453 Posted October 26, 2020 9 minutes ago, C. Andrew Dunning said: Now...what does NOT work is fixtures' auto-focusing from within DLVPs. Or Braceworks trim height functionality when moving an entire system hung from motors... Speaking of trim height, I can't believe I never noticed this before (sorry, I couldn't resist): Quote Share this post Link to post
C. Andrew Dunning 195 Posted October 26, 2020 9 minutes ago, Mark Aceto said: @C. Andrew Dunning I'm all good with truss and lights (and 3D objects that aren't hybrid). It only seems to be an issue with stage objects (which I guess I've never tried before) or other hybrid objects that aren't lights. You can add those things to DLVPs already raked but you are correct in that you can't adjust rake for DLVPs containing those objects. This is not new. Quote Share this post Link to post
C. Andrew Dunning 195 Posted October 26, 2020 6 minutes ago, Mark Aceto said: Speaking of trim height, I can't believe I never noticed this before (sorry, I couldn't resist): Insert snide comment. 😉 1 Quote Share this post Link to post
markdd 764 Posted October 26, 2020 Andrew. Maybe an idea for your version of the stage deck tools - The ability to remove the 2D Geometry from the Stage Deck Plug-in objects in the same way as you can for the Truss Objects. This would enable them to be used on Raked stages. 1 Quote Share this post Link to post
Mark Aceto 453 Posted October 26, 2020 (edited) 15 minutes ago, C. Andrew Dunning said: You can add those things to DLVPs already raked but you are correct in that you can't adjust rake for DLVPs containing those objects. This is not new. I guess I've just never tried rotating hybrid objects (other than truss, pipe, lights) in a DLVP, CPMV or SV before. I got here for this project because of the limitations of the Surface Array tool: And you know how I love to use the Landru / stock tools to work around missing functionality. On that note, is there a way to adjust the width of the "trim" of stage plug objects to match the profile of stage deck objects? Edited October 26, 2020 by Mark Aceto Quote Share this post Link to post
C. Andrew Dunning 195 Posted October 26, 2020 43 minutes ago, Mark Aceto said: And you know how I love to use the Landru / stock tools to work around missing functionality. On that note, is there a way to adjust the width of the "trim" of stage plug objects to match the profile of stage deck objects? At-present, no. The trim width is hard-coded. Quote Share this post Link to post
Mark Aceto 453 Posted October 26, 2020 1 hour ago, markdd said: Andrew. Maybe an idea for your version of the stage deck tools - The ability to remove the 2D Geometry from the Stage Deck Plug-in objects in the same way as you can for the Truss Objects. This would enable them to be used on Raked stages. The Draw 3D Only checkbox for the truss symbols would be my dream scenario for LED video screens too (adding the ability to insert 3D symbols of tiles and bumpers) 🙂 Not for nothing but I was able to fake a raked stage aka a "faked" stage 🤣 with the ramp tool but it has to be rectangular (no plugs for wings or thrusts), and the ends have to be vertical instead of tilting with the raked surface. That might actually help me with another project I'm working on... Quote Share this post Link to post
C. Andrew Dunning 195 Posted October 26, 2020 4 hours ago, Mark Aceto said: The Draw 3D Only checkbox for the truss symbols would be my dream scenario for LED video screens too (adding the ability to insert 3D symbols of tiles and bumpers Noted. 😉 1 Quote Share this post Link to post
