spries Posted October 22, 2020 Share Posted October 22, 2020 I would like to see the ability to have independent columns that follow a data set. Not being able to do calculations of separate cells in the same row of a data set is inconvenient. Quote Link to comment
0 Pat Stanford Posted October 22, 2020 Share Posted October 22, 2020 You can do calculations in database rows. It just has to be the same formula for every subrow in the database. Try this. Create a file and put a couple of rectangles in the file. Create a worksheet with a database criteria of Type is Rectangle. I am going to use Row 3 for my example. Set the formula for Column A to be =Width. For Column B to =Length. For Column C. =A3*B3 When you recalc the worksheet it will take the current height and width of the rectangles and multiply them together to get the area. You don't even have to use cells in the same row. If you set cell A1 to be 2 and set formula for column D to be =C3*A1 you will get the area of both sides of the rectangle. The only real limitation to databases is that everything must either be a Record.Field or a calculation. You can not just type something into a cell unless it is a Field. HTH Quote Link to comment
0 spries Posted October 22, 2020 Author Share Posted October 22, 2020 @Pat Stanford You are correct. However, if I want to enter information that is not in the drawing or in a record I hit the limitation. For example, I have an LED wall with multiple LED panels, Bumpers, cables etc. If I want to add a column for the weight or a column with the power consumption for each line item I can not do that. Quote Link to comment
0 Pat Stanford Posted October 22, 2020 Share Posted October 22, 2020 Sure you can. You just need to either pick one of the user fields to store the information or add a custom record format to store the data. Since Databases are completely dynamic, unless the data is stored in a way that is truly associated with the object, there is not way for VW to keep the data with the correct objects when the database changes (whether that is due to adding or removing objects to the drawing, changing the sort order, or SUMmarizing the data. Quote Link to comment
0 ScottLebsack Posted October 23, 2020 Share Posted October 23, 2020 (edited) @spries Pat is correct. Even though it is frustrating at times, what you're after is possible. You need to add data fields to an existing record applied to the objects, or create a new record and add it to the elements you're querying. The database row criteria only specifies the objects in the file it is looking for. You can create a data column from any record field those items have attached. Each column can only reference one record field, but you can have empty rows if the data is not applicable (you can't mix record fields in the same column). It's easy to create a note record that is blank, once it's attached to the objects and referenced in the worksheet column, you can fill it in directly from the worksheet. Edited October 23, 2020 by ScottLebsack Quote Link to comment
0 Pat Stanford Posted October 23, 2020 Share Posted October 23, 2020 9 minutes ago, ScottLebsack said: you can't mix record fields in the same column Actually you can, but it takes some potentially tricky IF and/or CONCAT functions. And then you have a cell/column with a formula instead of a Record.Field entry so you can't edit what is displayed. Sorry, the completionist in me is coming out this morning. ;-) Quote Link to comment
0 ScottLebsack Posted October 23, 2020 Share Posted October 23, 2020 @Pat Stanford I've been hoping to tackle formulas in worksheets, can you point to any video resources, the lists of possible formulas are difficult to learn from? Quote Link to comment
0 Pat Stanford Posted October 26, 2020 Share Posted October 26, 2020 Unfortunately, I can't point to any video sources. I think @michaelk did a webinar a while ago. It might be up on Vectorworks University. @Jonathan Pickup almost certain has some on his (paid) site also. I am much more of a text guy than a video guy. Sorry. Quote Link to comment
0 michaelk Posted October 26, 2020 Share Posted October 26, 2020 I haven't seen the webinars I did for a while. The UI has changed a little. Remember the triangle? But working with formulas is still the same. If you go to https://university.vectorworks.net and search for worksheets you will find some videos. Quote Link to comment
spries
8 answers to this question
