GetVSVar not working properly? MD5 in Vectorscript
AFDesign
Hi,
this is the first time I try to use Python code inside Vectorscript, and I can't understand why by "importing" a variable in Python (using GetVSVar) the first character is automatically deleted.
I'm trying to retrieve an MD5 hash from a string:
procedure MD5test;
var mystring,myMD5string:STRING;
begin
	{importing the correct string}
	mystring:='test';
	PythonBeginContext;
		PythonExecute('import vs');
		PythonExecute('import hashlib');
		PythonExecute('thestring=vs.GetVSVar(''mystring'')');
		PythonExecute('vs.AlrtDialog("Imported in python <"+thestring+">")'); {string lose the first character!!}
		PythonExecute('myhash=hashlib.md5(thestring.encode())');
		PythonExecute('vs.SetVSVar("myMD5string",myhash.hexdigest())');
	PythonEndContext;
	alertinform(concat('input string: <',mystring,'> wrong result (result for "est"): ',myMD5string),'',false);
	{importing the string with a starting space}
	mystring:=' test';
	PythonBeginContext;
	PythonEndContext;
	alertinform(concat('input string with starting space: <',mystring,'> correct result: ',myMD5string),'',false);
	{using the string directly}
	PythonBeginContext;
		PythonExecute('myhash=hashlib.md5(b"test")');
	PythonEndContext;
	alertinform(concat('correct result using "test" string directly in python: ',myMD5string),'',false);
end;
run(MD5test);
I tried with Vectorworks 2020 and 2021, same problem. Maybe I'm doing something wrong?
Thanks!
Using "mystring:DYNARRAY[] OF CHAR;" the hash is generated correctly, but now the result start with a white space. There is the same kind of bug to report..
Thank you
procedure MD5test;
var myMD5string:STRING;
begin
	mystring:='test';
	PythonBeginContext;
	PythonEndContext;
	alertinform(concat('<',myMD5string,'>'),'',false); {result start with a white space}
end;
run(MD5test);
Edited by AFDesign
forgot old comments
I am not seeing an extra space here in VS2021SP2.
Try this one. I have put asterisks on either side of the VS String to specifically look for white space.
PROCEDURE Example;
VAR
  strName : DynArray of Char;
BEGIN
  strName := 'vs string';
  PythonBeginContext;
  PythonExecute( 'import vs' );
  PythonExecute( 'ss = ''hello from python: *''' );
  PythonExecute( 'vs.AlrtDialog(ss + vs.GetVSVar("strName") + ''*'')' );
  PythonExecute( 'vs.SetVSVar("strName", "python string")' );
  PythonEndContext;
  AlrtDialog( Concat( 'VectorScript received: *', strName, '*' ) );
END;
RUN(Example);
I am not seeing a problem with SetVSVar here. What do you get when you run the following script?
PROCEDURE Example;
VAR
  strName : String;
BEGIN
  strName := '';
  PythonBeginContext;
  PythonExecute( 'vs.SetVSVar("strName", "python")' );
  PythonEndContext;
END;
RUN(Example);
It's true, if you simply "replace" a string there is no problem. But if you process the variable as in my example, the result has a white space, that disappear if you use "Dynarray of Char" instead of "string".
Your example with hash process and String variable (white space in the result):
PROCEDURE Example;
VAR
  strName : String;
BEGIN
  strName := '';
  PythonBeginContext;
  PythonExecute('thestring=vs.GetVSVar(''strName'')');
  PythonExecute('vs.SetVSVar("strName", myhash.hexdigest())');
  PythonEndContext;
  AlrtDialog( Concat( '*', strName, '*' ) );
END;
RUN(Example);
Same example using Dynarray variable (correct result):
PROCEDURE Example;
VAR
  strName : Dynarray of Char;
BEGIN
  strName := '';
  PythonBeginContext;
  PythonEndContext;
END;
RUN(Example);
Maybe is something linked to string encoding in python.
Sure! Same code, but string is directly assigned in python:
PROCEDURE Example;
VAR
  strName : String;
BEGIN
  PythonBeginContext;
  PythonExecute('thestring="test"');
  PythonEndContext;
END;
RUN(Example);
SetVSVar return the white space, after encoding the hash.
I think I will not use this phyton code because it works only if the plugin is not encrypted. After encryption, the plugin freeze Vectorworks. If I remove the code and encrypt the plugin, it works. Maybe plugin encryption cause some problems to python code, I will try to understand why.
I discovered why my plugin freeze: after encrypting the plugin and rebooting vectorworks, SetVSVar returns an empty variable.
You can see the problem by creating a new plugin with this simple code:
procedure testsetvsvar;
VAR
	result:STRING;
begin
	PythonBeginContext;
	PythonExecute('vs.SetVSVar("result","PYTHON TEXT")');
	PythonEndContext;
	alertinform(concat('text from python : ',result),'',false);
end;
run(testsetvsvar);
Without encryption, the plugin works correctly.
If you encrypt the plugin and reboot Vectorworks, text from python result is empty.
Yes, as I said previously, if you simply "replace" a string there is no problem, SetVSVar works correctly, and the white space isn't a problem if I use Dynarray of Char.
The problem is that after encrypting the plugin, SetVSVar returns an empty value, as you can test in my last example (without using any other python code).
